92-95 d series clutch plate with 91 d series transsmisson
Discussion in 'HYBRID -> ED-EF / DA' started by Travisl, May 17, 2009.
  1. Travisl
    Travisl New Member
    wichita,ks
    will a 92-95 d series clutch plate and pressure plate work with 91 d series transsmisson the motor is a z6
  2. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    as long as your clutch pressure plate and flywheel are for the same as the tranny then yes. in your case, as long as your splines on your 91 tranny match the splines on your 92 clutch then yes. make sure your flywheel is the correct one for your clutch tho.
  3. Travisl
    Travisl New Member
    wichita,ks
