92-95 Si/ex Intake Manifold On D15?
Discussion in 'HYBRID -> EG-EK / DC' started by dansace, Apr 15, 2003.
  1. dansace
    dansace Member
    ATX
    i have a 92 civic cx which has like a 42mm TB bore and I have the chance to get an ex manifold with the TB for fairly cheap. Will it bolt up to my d15?
  2. E_SolSi
    should work fine
  3. Vtec_si
    Vtec_si Junior Member
    Should work fine but it depends on what series d15 you have. If it came out of a 88-91 car, then you will have to modify the engine harness for four injectors. You will also have to have the ecu from that vehicle.
  4. solblu
    solblu Senior Member
    Ricer
    Well they said 92 CX, so this info is irrelevant.
    It bolts up fine, one coolant line is different, but it's easy to figure out where it goes.
