boostedf22
dis is why im not
A little about the car:
JDM F22B dohc non vtec (Almost the same as the usdm H23)
I changed the car from an auto to a 5spd with an h2s4 tranny with a wavetrac diff.
The motor is all stock other than an short ram intake and a header.
The motor was tuned on a dyno and ran good for about 3 months.
The problem:
Before the 2 step was set at 7k rpm, when sitting still and trying to rev the car up. It will reach 5500-6000 rpm and slowly bog back down to 4500rpm and back up to 6000rpm. Its not taching out like it should be.
When driving down the road and trying to tach out the rpm's. The car will not go past 6k rpms. More or less does the same thing that it has been doing when sitting still. It also has a different sound from the exhaust then what it had before the issue started. Deeper sound from the exhaust.
Things I have done to try and eliminate the problem:
Replaced the Map sensor
Replaced the fuel filter
Replaced the fuel pump (255LPH)
Replaced the rotor button
Replaced the distributor cap
Replaced the spark plugs
Replaced the spark plug wires
Checked all grounds and they are in tact.
I am running a p28 chipped on Neptune. I am not getting any CEL's
So I am thinking it could be the coil pack? Distributor? Since I have eliminated the fuel issue, maybe its something deeper with the ignition?
I am hoping someone else has had this issue or may know about my problem.
I can supply Video if needed.
__________________
The problem:
__________________
