calmfornow
System Failure Racing
ok so i picked up a 92 accord off of my friend. Has one annoying problem, when you start it up for the first time of the day or if it sits for about an hour it will idle rough and if you even tap the gas, it will try to stall out then rev up to about 1000-1200 rpm, then drop down and do it a few times then go to regular idle if it doesnt stall, after about 5-10 min of running it runs fine....i noticed spark plug tube has small amount of oil in it, but i replaced plugs, and wires and even did it when they were fresh. it has a intake, header, high flow (AKA test pipe), and a cat back system. everything else is basically stock. replaced external coil, checked all vacuum lines and locations. i did notice on my other accord there was a solenoid looking thing that had vacuum lines going to it and wiring by the air filter, but this one doesnt could that be it? any help would be great thanks
