92 Accord timming belt
Discussion in 'Accord' started by heyduck, Nov 25, 2010.
  1. heyduck
    heyduck New Member
    i just bought my first Honda it didn't run when i bought it got it figured out it was the timing was off got it fixed and now it runs just cant the the timing belt tighten if some one could tell me how to going about doing this that would be nice oh and the tencheners pulleys have been change alone with the water pump lol
  2. heyduck
    heyduck New Member
    sorry its has the F22A in it
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    use a ratchet on the crank to pull all of the belt slack out "front" side of the crank/cam, and then proceed with tightening the tensioner.
  4. heyduck
    heyduck New Member
    i have done that like four times and its still lose
  5. K2e2vin
    Raleigh, NC
    can you tell if there's areas where the belt is tighter than other areas? Also, to pull the slack out did you actually rotate the engine one or more times, or just turned it enough to pull out slack?
  6. heyduck
    heyduck New Member
    ive rotated it like 3 turns from the crank and it the front is some what tight and the back is really lose
  7. heyduck
    heyduck New Member
    its so lose if i put the cover back on it would slap it, Ive drove it it dont act like its really lose but i dont want to jump time if i have to get on it
  8. K2e2vin
    Raleigh, NC
    I guess make sure the tooth count on the water pump is right, and make sure you infact have the correct timing belt.
  9. Hondadude141
    TX
    That's my guess, that you have a timing belt that's lightly too big, or meant for another engine.
  10. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    i would agree, because that motor has an automatic tensioner, either the pump is wrong or the belt is to big
