92 civic 4 door swap
Discussion in 'HYBRID -> EG-EK / DC' started by 92civic4door, Jun 9, 2010.
  1. 92civic4door
    92civic4door New Member
    k i have a 92 civic 4 door we did a d16y8 swap a few years ago now im bored with that im going for the next step. i bought 98 teg with a OBD1 gsr swap in it. its a write off so its just a parts car now. my question is what all do i need to do this swap ive been reading looks like i use the teg motor mounts??? what do i use for a wiring harness???
    thanks for the help steve
  2. E_SolSi
    use the integra harness
  3. 92civic4door
    K that's easy then kinda makes it just plug and play then right? Now what about motor and tranny mounts there seems to be alot a mixed answers on the net. Do I use the integra mounts or the civic ones ?? Or do I buy swap mounts??
  4. GSRvic93
    GSRvic93 New Member
    I used the mounts from the teg, the motor mounts were aftermarket but the tranny was factory.[​IMG][​IMG][​IMG]
  5. 92civic4door
    pics didnt work do you have any more info on this swap?? theres lots on the net but theres no forsure anwsers for anything.
  6. shadyman8
    shadyman8 EG9
    Utah
    you use that teg mounts, wiring harness, axles and shift linkage, and ecu if it is obd1, all of it should be a direct fit.... the factory wiring harness on the civic should also already be wired (http://www.phearable.net/tech/wiring/obd1shocktowerwiring.jpg) check to make sure with this link... and you should have a fast nice easy reliable swap.
  7. egb19c
    egb19c New Member
    Use all the teg parts, thats a direct swap
  8. 92civic4door
    thanks for the help guys cant wait to get this in should be a nice change more power and still a daliy driver. whats a good clutch flywheel combo for this set up i thinking on a all motor build for it over the winter nothing to crazy maybe hit the mid 200hp range.
  9. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    No lightened flywheel needed.....wont change that much at the hp you want (let alone what you might have now). Resurface your flywheel and IMO get an Excedy clutch (decent quality and price). I STRONGLY suggest you also get a OEM Honda throw out bearing. I did the other 4 times I've changed Honda clutches and didn't on the last one......it squeals all the damn time and irritates me (I even greased it before install)
    92 Civic.....so you are already wired for VTEC from shock towers to the ECU (make sure you get a OBD1 P72 ECU if you dont have one already). If the GSR swap has the GSR Engine Harness on it (all VTEC wiring is from factory and in the wire loom/plug) thn you are in good shape. Do what everyone else says and use all the integra stuff (shift linkage too!) Plus run the knock sensor line to the ECU (I think its D3 on the ECU but dont quote me) But you need a Donor Pin to plug intot he empty slot for the new knock sensor line that will be needed for the P72 ECU
  10. 92civic4door
    that was random :gives: lol just bugging we started there to but i want coilovers now tho i have H and R springs and toikco blues for sturts rides nice and has a pretty good ride height could be abit lower tho. i think ill ur advise on the flywheel clutch combo CAFROG i was kinda thinking the same. i cant wait to get the swap started been raining here and the teg is outside.
  11. CAFROG
    NOR-CAL
    What was random? You asked about the swap parts needed and clutch/flywheel options.
  12. 92civic4door
    lol last night there was a post after yours and it was ramdom as shit somthing about some guy 91 teg he wants more HP but wants to do handleing first thats funny he got ride of it.
    and ur info helped me alot i found those plugs for vtec
