92 civic cx hatch B series swap!!!
Discussion in 'Civic and del Sol - EG and EK' started by lewellgd, Apr 24, 2007.
  1. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    I have a question about b series engines i no they bolt right in with b series mounts but what about wiring is there any wiring i need to do or should it be fine.
    And what year did integra switch to obd2
  2. eg6sir
    integra switched to obd2 in 96.. but yes, with mounts, axles and linkage.. its pretty much a straight swap.. all 92 civics were wired for vtec from the factory.. so if you're swapping a vtec motor you'll need to run a wire for the knock sensor and extend the vtec wire
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    realy vtec wires and all are already there ?
  4. eg6sir
  5. AHHVTEC
    Alabama
    well if it is awesome didnt know that
  6. eg6sir
    yea,.. its wired from the ecu to the shock tower.. so you need to wire the vtec from there or find an EX/SI/VX engine harness
  7. lewellgd
    Crap
    I think i screwed up bad!!!!!!!!!!!
    I got a b18b1 out of a four door automatic integra!!! OBD1
    The tranny 5spd ls i bought says 97 on it UMMMMMMMMMMM!!!
    Does that mean it is obd2??????
    If so what problems do i have.
  8. AHHVTEC
    Alabama
    the tranny doesnt matter it will bolt up and work fine
  9. TheManRSW
    TheManRSW TheManRSW
    Trans should be okay. I think b-series trannys are all pretty interchangable, but there may be an exception to that.
  10. lewellgd
    So i dont have linkages so what linkages will fit and work on my car or do i have to buy some from a swap site.
  11. AHHVTEC
    Alabama
    just buy some from hmotorsonline.com
  12. lewellgd
    I couldnt find any on there but a good site for that kind of stuff is NOPI MOTORSPORTS
    They are a pretty good site easy to search as well.
  13. AHHVTEC
    Alabama
    call h motors and tell them what you need
  14. 8thchild
    8thchild Junior Member
    h motors is the shit thats where one of my boys gets his stuff and i might get a few things to
