92 Civic DX engine into 91 CRX DX
TurboMirage
That’s how you get ants
VIP
i have a mint 92 dx engine out of my wrecked hatch... i also have a d16z6 from an ex that i bought. i want to put the d15b7 outta the hatch and into the crx... what is required and what wiring will i need?? eventually i want to go mini-me after i have the vtec head ported and polished.
any help would be much apprecieated.
you are gonna need to do one of two things, either...
A. remove the 91 DX intake manifold, and distributor and put it on the 92 motor, then it will all plug in and you would basically have the replacement. this way would be the cheapest, but has no performance gains, it would basically cost you 20 bucks for an intake manifold gasket.
B. the performance way. convert your DPFI wiring to MPFI, get an si ecu, get an si distributor, 88-91 si or 88-89 teg injectors and resistor box, then you would basically have the power an Si has, generally 105-108 roughly around there
