92 Civic HB
Discussion in 'HYBRID -> EG-EK / DC' started by jokeintegra, Jun 27, 2006.
  1. jokeintegra
    jokeintegra Junior Member
    Milwaukee, WI
    So I have a 92 civic hatchback that I bought with a B18C1 (gsr) engine and a P28 ecu. Which catylitic converter should I use and where do I connect the wires for the o2 sensor! Thanks in advance for any help!
  2. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    Get, at least, the cat that was made for that engine. You should have a 4 wire connector for the o2 sensor. You don't have one at all on it now???
    Actually you may not have a 4 wire connector for the o2, depending on what harness the person before you used. Either way, look for the connector without anything on it. Location depends on what harness is in the car.
  3. jokeintegra
    Milwaukee, WI
    I just noticed that there wasnt a cat on it the other day! First time Ive been under the car since I purchased it. Im pretty sure that its the stock civic harness!
    Ill post pics to give a better idea!
