92 civic Si v.s. CX model???
Discussion in 'HYBRID -> EG-EK / DC' started by 90htchbck, Dec 23, 2007.
  1. 90htchbck
    90htchbck New Member
    whittier
    just wondering, i have a 92 civic si hatch, car weighs 2326lbs, where as the CX model only weighs 2094lbs....where does the Si gain 232lbs, where is the weight added to the Si??? still has manual windows and door locks, only difference i know of is the sunroof but does a sunroof weigh 232lbs???
  2. knuteiriktveiten
    knuteiriktveiten New Member
    Louisiana
    might have a different suspension setup or something?
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    Sunroof, I believe a larger gas tank, power everything, rear wiper assembly. Few things here and there.
  4. knuteiriktveiten
    Louisiana
    he siad his si has manual windows n locks
  5. 92civicb18b1
    Oh didn't read it, I believe the sunroof is at minimum 125 lbs with everything.
    All the little things add up though. Yours probably doesn't weigh 2326, I think that was the gross weight for a fully loaded.
    AC/PS probably weigh about 50lbs together.
  6. eg6sir
    the SI comes with more sound deadening on the floor, sunroof, ac, power steering, rear discs.. thats where all the weight comes from
  7. Dasfinc
    Dasfinc New Member
    As far as the big heavy stuff:
    Sunroof
    Bigger gas tank
    More trim/sound deadening material
    more power tid-bits
    AC
    PS
    and atleast a front, if not a front and rear swaybar.
  8. knuteiriktveiten
    Louisiana
    my 95 dx came with a front sway bar...
  9. 90htchbck
    whittier
    and a dx is heavier than a cx
  10. Dasfinc
    Dasfinc New Member
    DX has more trim and a bigger gas tank I know for certian, and they often have PS and AC
