92 eg hood on 95
Discussion in 'Civic and del Sol - EG and EK' started by EP3Hatch1987, Jul 7, 2009.
  1. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
    I'm having problems putting a 92 civic hood on my 95 do I need 2 do some mods?
  2. eg6sir
    is it a 4dr hood?... if so, it wont fit
  3. EP3Hatch1987
  4. eg6sir
    ok then.. what problems are you having?
  5. EP3Hatch1987
    It's not going down all the way.. And not sitting flush with the fenders.. It's a carbon fiber hood
  6. 95b16coupe
    95b16coupe New Member
    ct
    could be the carbon fiber is tweaked. is it a brand new hood or is it used? also, has the car ever been in an accident. it could have a bent core support.
  7. EP3Hatch1987
    It's used and never been in any accidents.. But I think the carbon fiber might be a Lil warped cause it's sits closer 2 the fenders on the passenger side more then the driver side..
  8. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Well...color me stupid but did you ADJUST IT? Is this your first BBQ? You need to fiddle with
    the mounting points of the hood....and maybe the fenders too. Your car been in an accident? Or
    maybe the other car it used to be on was in an accident (before the hood....duh...I can read)
    Its called checking your gaps. Sorry to be an ass but if all you did is based on all you wrote...you
    haven't done really anything. The gaps need to be the exact same all the way down each fender
    and the gaps on each side of the hood need to be even too. There are adjustments on the
    hood....left fender...and right fender. Mess with them all to achieve even body lines.
    Most of these stupid carbon fiber hood shut like crap too. I see so many guys rolling around with
    a hood that takes them five minutes to shut 'properly'......and we wonder how we hear of Civic
    owners who's hoods fly up on them down the highway.
  9. eg6sir
    only way i'd ever run a CF hood is with hood pins.. that way i know it wont fly up..
    but i'm w/ CAFROG ... you need to adjust it.. cant just bolt it on once and have everything line up...
  10. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    Aftermarket has a lot of fitment issues to boot, OEM is by far the best. Good luck though!
  11. EP3Hatch1987
    I messed with it a little lastnite and did the best I could in the dark but I'll mess with it some more and adjust the fenders and see what happens and I'll give you guys and update if I have any problems doing so..
  12. EP3Hatch1987
    Yess this is my first BBQ.. And you guys recommend hood pins 2?
  13. serrilion
    serrilion In my own little world! VIP
    Vermont
    Always :) Hood pins are so nice, tho i kept my stock latch cause of theifs in the area lol, but also I would look into fiberglass :) I love em, tho some here may no agree with me
  14. EP3Hatch1987
    What bout the NRG hood pins with the key?
  15. CAFROG
    NOR-CAL
  16. eg6sir
    if they lock.. even better
  17. EP3Hatch1987
    Yup they lock.. And I got the hood 2 fit it took a little messing around with.. But I think it's a Lil warped..
    I was wondering what wax would be good 2 bring bacc 2 life?
  18. CAFROG
    NOR-CAL
    Wax? Talking about the finish getting dull? Re-Clear coat it. You can use rattle can clear if you don't have a air spray gun (in a controlled environment)
    Wet sand it down (at least 2 diff grits) to take out imperfections and then spray the clear on in Multiple coats (like 4-6 super light coats) then you can wet sand once more (lightly and high grit) then maybe 2-3 more light coats and see if you need one more round of sand/clear but it could be good to go at that point.
  19. TurboRex90
    TurboRex90 Golden EG
    Maryland
    I ran hood pins on my old CF hood, but i didnt have the hoodlatch on it, hood was used so it was missing. But the hood latches were keyed and one malfunctioned and caused my hood to open at 60mph, and by malfunction i mean yes i did lock them, but part of the latch itself broke... the part attached to my core support.
    I have a new CF hood now with a workin hood latch, but i dont want to defile the hood with pins. Though it would be safer.
    Though when i get around 60mph i get nervous that this hood will do the same thing. It sucks.
  20. eg6sir
    dont buy cheap parts then..
