EP3Hatch1987
Meeeeooowww!!!!!
Wax? Talking about the finish getting dull? Re-Clear coat it. You can use rattle can clear if you don't have a air spray gun (in a controlled environment)
Wet sand it down (at least 2 diff grits) to take out imperfections and then spray the clear on in Multiple coats (like 4-6 super light coats) then you can wet sand once more (lightly and high grit) then maybe 2-3 more light coats and see if you need one more round of sand/clear but it could be good to go at that point.
I'll prolly end up doing that.. But I did a Lil searching around and a lot of people are using the turtle wax ice?
