  1. mvokidd
    mvokidd New Member
    help :huh: when I turn on the light switch only front lights turn on nothing else beside when I push the brakes.
    -no day time running lights
    -no dash lights
    help me outtt Honda SQUADD!:rimshot:;)
  2. Fernpatch
    Fernpatch Member
    Bellingham,WA
    When you say the "front lights" do you mean headlights? If you have headlights and nothing else than it is most likely the light switch itself or a bad wire in the steering column.
  3. Matts96HB
    Matts96HB . Moderator VIP
    Check fuses also. Quick and free
  4. mvokidd
    mvokidd New Member
    alright what guys thank you do you know in mind what fuse box under steering or the fuse box in the under hood??
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Check them both. Most of your lighting fuses will be in the dash fuse box.
