92 hatchback b18 swap
Discussion in 'Civic and del Sol - EG and EK' started by bannacrx, Apr 24, 2007.
  1. bannacrx
    bannacrx New Member
    k got a 92 hatch d15 non-vtech. just got an integra ls motor with 30k on it, b18b1, whats required for the swap? im sure theres a thread somewhere but i just didnt find b.c i r retard. axles, ecu, shift linkage?, gsr ecu would plug right in correct? also want to take a vtech silenoid i have and pop it on the ls, is it tech ready? motor should drop right on the chassis with the integra mounts correct?
  2. TheManRSW
    TheManRSW TheManRSW
    no no no. Head is not built for vtec has non vtec cams. GSR ecu is made for vtec. vtec solenoid will not work on ls head. If you get a vtec head say b16...you can have a vtec motor.
  3. bannacrx
    bannacrx New Member
    can i still use the gsr's ecu and wiring harness? im not sure if the ls ecu i have still functions. or cna i use the ls wiring harness on the gsr ecu?
  4. TheManRSW
    TheManRSW TheManRSW
    Don't think so...Harness will have extra plugs and ecu will be looking for more inputs than what the ls engine will give.
  5. bannacrx
    bannacrx New Member
    k last question what axles can i use
  6. TheManRSW
    TheManRSW TheManRSW
    I honestly don't know. I would say the ls axles should work but I don't know if spline count for the hubs will match.
  7. TheManRSW
    TheManRSW TheManRSW
    Basically with an ls swap you need to use ls stuff. You will need the ls ecu, harness and trans if you want to just swap in the ls motor. If you want to make an ls/vtec motor you will need to mix and match. For ls vtec you will need harness with vtec, vtec head from a b series engine and possibly a gsr transmission (ls trans will work but gearing will kill the power)
  8. TheManRSW
    TheManRSW TheManRSW
    I am not positive and if I am wrong I assume someone will correct me soon.
  9. bannacrx
    bannacrx New Member
    well heres the good thing, i have a b18c1 to work with in a crx. im prolly just gonna use those axles. thats why i was wondering about doing the vtech swap. ppl ask me why i dont drop the c1 into the 92 hatch. motor is very unreliable due to previous owner. i dont have the money to deal with it right now. the ls has 30k on it.
  10. TheManRSW
    TheManRSW TheManRSW
    VTEC***
    Vtech makes phones
  11. bannacrx
    bannacrx New Member
  12. TheManRSW
    TheManRSW TheManRSW
    Understandable...do what you can to get the ls engine swapped and running...then go from there. If you want to change stuff later it will be much easier to work with stock components.
  13. TheManRSW
    TheManRSW TheManRSW
    Research research research...there are tons of people on this site with a wealth of knowledge. Look around at previous posts and figure out exactly what you want to do before you start.
