94 ls axles and intermediate shaft will not fit in my 92 hb with 1st gen b16..they r too long. i thought they were supposed to fit..y aren't they?!?!?!??!?
You need to use the axles from any Si civic. As far as I know just use 92-2000 Si Axles and it should work. Also The 90-93 integra ls axles work(I think). That's my input.
Originally posted by 93cxhatch@Oct 7 2003, 09:31 AM You need to use the axles from any Si civic. As far as I know just use 92-2000 Si Axles and it should work. Also The 90-93 integra ls axles work(I think). That's my input.
Well, um, no. The 92-95 Si's had D series motors, which do NOT use a halfshaft, and the 99-00 Si had the B series, which does. He needs to use a B series axle.
H22bubbleback, have you considered the possibility that you are trying to cram a D series axle in there?
Originally posted by 93cxhatch@Oct 7 2003, 12:31 AM You need to use the axles from any Si civic. As far as I know just use 92-2000 Si Axles and it should work. Also The 90-93 integra ls axles work(I think). That's my input.
dude, don't give advise if you don't know WTF you're talking about. and trust me it doesn't sound like you know what you're talking about.
i'm with 92B16VX, get some axles from a 99-00 Si, you're guaranteed a perfect fit. The axles off of a 94-97 Del Sol Vtec will work also. Basically any B-series axles will work.
Originally posted by 92civicb18b1@Oct 9 2003, 03:27 PM um yea, if he said it was a 1st gen b16 and hes usin the tranny from that it's cable, so 90-93 integra axle should fit.
Try to trade that tranny for hydraulic, since your car was originally hydrualic it'll just be easier, plus that way I know 94+ integra axles fit.
yea but he wouldn't be stupid enough to convert his 92 civic to a cable actuated clutch, he would simply swap out the tranny for a hydraulic one and plus he just told us that the tranny is hydro.
