92 Integra GS - Engine Shuts off while driving...
Discussion in 'Integra' started by Subz, Aug 11, 2008.
  1. Subz
    Subz New Member
    I have a '92 Acura Integra GS. I'm having issues where the engine will stop while I'm driving. Is is intermittent, where it could happen three times in one day and then it won't happen again for a week.
    The RPMS are little jumpy before the engine stops and there usually aren't issues restarting the engine.
    From some of the posts I've been reading, it could be the ignition coil or fuel pump.
    Any thoughts?
    Thanks
  2. salvadorrivas13
    salvadorrivas13 New Member
    San Jose CA
    You should check your fuel presure, and try a different dizzy, or differnt main fuel relay. But you should look for loose wires or check you battery terminals you know look around your Engine bay.....
  3. Subz
    Subz New Member
    Great. thanks for the advice. I'll give it a try.
  4. 92tegGP
    92tegGP The Slut
    North Jackson, Ohio
    check your main relay and your grounds for sure. especially the one on your thermostat housing. i had that same problem and thats what was the matter with mine. good luck
