92 lx with a f22b1
Discussion in 'Accord' started by 2accords, Sep 19, 2009.
  1. 2accords
    2accords New Member
    i swapped my 92 lx and get get it running right. used a motor out of a 96 acura and ecu from 96 accord ex. got a rywire custom harness and the obd2 jumper harness. the car runs great except from 1300rpm to 2000rpm, seems like the timing is off but why? what can i do to fix this? it has been at 3 shops for over 2 years. im in pittsburgh pa and will drive any resonable amount for help.any input would be great
    email is onesikacr@verizon.net if you wanna email
  2. 2accords
    2accords New Member
    anyone have any oppinions on this....
  3. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Yeah you shoulda kept the F22, without vtec they can make more power than the vtec F22b. As to your problem, i really am not sure. Why didnt you keep the obd1 harness and distributor though. You could have used that and then ran you vtec wires from the engine to ecu. Sounds like you did some uneeded work.
  4. 2accords
    2accords New Member
    my motor was killed got this one with tranny, with only 13,000 miles couldnt pass it up. i never swapped a car before, talked to Rywire and they said to make the 2 harness's into 1 . to late use the stock harness now. i tried though before i sent it out and plugs were short among other things
  5. 2accords
    2accords New Member
    i did a TON of useless work. had the car 3 months started the swap, in july of 07!! it hasnt ran right since thousands of dollars on parts , shops , and labor not to mention the 1000 phone calls about the car. i need it running it was supposed to be my beater not my project car...
  6. caboose
    caboose USDM to the bone
    Hamilton, MI
    what do you mean it doesn't run good? is it misfiring, or just slow.
    fyi... my accord doesn't hardly have any power down that low... i can feel a big jump at around 2000rpm
  7. 2accords
    2accords New Member
    it is cutting out and bucking. not slow, past 2000rpm and it runs smooth to redline, it is misfiring from one thing or another, not plugs wires ect...
  8. 2accords
    2accords New Member
    what could be causing this?? anyone?
  9. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Throttle position sensor?
  10. 95b16coupe
    95b16coupe New Member
    ct
  11. 2accords
    2accords New Member
    replaced it already it feels like a timing issue, but why only through a certain rpm?
  12. 95b16coupe
    ct
    because the timing is off. lol
  13. 2accords
    2accords New Member
    tried to adjust the timing but there is no movement on the cap. changed the TPS ensor again didnt help. changed the MAF sensor didnt help, i give up!! 13,000 miles on motor and tranny new suspension and paint $1000.00 OBO
