beleave it have managed to fit a 92 prelude h22a into a 88 prelude 4 wheel steering want somthing differant. now wiring i have all the wiring and computers out of the 92 prelude minus the engine not going all electric's work on the 88 prelude so all i need to do is find a way of separating the computer on the 92 wiring and install it in to the 88 prelude to get the engine running. im i going the right way about it or is there a easyer way. can sombody point me in the right dirrection on what to do cheers kedgenz
I'm sure that you could get the computer to be a standalone, seperate from the car. But there lies the problem. If you do that, none of your guages will work. What you have is a wiring nightmare.
if you havent already, get a helms manual for both the car the motor came out of and the car you have. sit down with all the wiring diagrams, grab your soldering iron, and start splicing. its not gonna be fun, but its the only way. you may want to call someone like hasport, they may either have or be able to cook something up for you, i know they do wiring harnesses for almost every honda/acura swap. not cheap though.
JDM Preludes did, hence you can get an engine from 1992 with an engine code of H22A, but you CAN'T get an engine from 1992 with a code of H22A1.
