92 si engine swap
Discussion in 'Prelude' started by port3s, Aug 22, 2008.
  1. port3s
    port3s New Member
    Hey guys, ive got a Prelude si 2.3L 4ws i want to change my 2.3L engine to a 2.2L VTEC whats the best way to do this?
    ive seen for sale a new H22A motor for 2.5K is this a decent price comes with ECU.
    any advice?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  3. port3s
    port3s New Member
  4. port3s
    port3s New Member
    can i just drop the H22A motor with the ECU into the car or do i need to change anything else like breaks, suspension or anything else??
    also any idea where i can get a H22A motor cheap..
  5. AHHVTEC
    Alabama
    you dont have to tyou can even use your stock trans, just get the motor and ecu and your ready. and yea read my first post lol
  6. port3s
    port3s New Member
    thanks alot mann... verry berry!! lol tnx
    do u recomend a H22A motor or something else? bigger, more powerfull
  7. AHHVTEC
    Alabama
    well if you got deeep pockets id go with the k20a but the h22a is easy and cheap to put in that car
  8. BrutalB83
    Rochester Hills, MI
    Why would you need to change the breaks or suspension? The motor is almost exactly the same size and weight as your current one, and it will bolt up to the existing transmission as well. If you want to upgrade those things you can, but there's no need to otherwise...
