92 teg B16 Swap, Dizzy Questions
rufio0306
The engine i am getting is an obd0 and the teg is a 1, Can i just get a diagram and pinout the white plugs and pin them into the gray plugs to work. What should i do. getting engine tomorow and need to get the advice in advance. thanks...:huh: i will be wiring in the vtec solenoid and pressure switch in myself and do not want to buy a harness.
