92'CX 1 to 4 wire 02 conversion for 93'pr4
bavarianblessed
Ok,i think i have located the spots on the CX plugs where the wires need to
be added,but which wires go where?Also can i use a obd2 02 sensor or do
i need to get an obd1?(i allready have the obd2 from the donor car,why im asking)
The o2 is the same OBD II, OBD I doesn't matter, the difference is the what the ECUs look for. As long as it's a four wire, you'll be good.
