92EX to 93LX engine swap
Discussion in 'Accord' started by joecyrix, Sep 15, 2012.
  1. joecyrix
    joecyrix New Member
    Just swapped a 92EX into my 93LX. Everything swapped perfect, starts and runs fine, but after 2-3 minutes the alternator starts smoking. Disconnect the Green 4-wire plug and it stops, but obviously so does the charging of the batter. Put the old alternator on with same result. Anyone know of a difference in the wiring, or did I pinch a wire somewhere...?
  2. Briansol
    Check the grounds. it may be over charging due to lack of a solid circuit.
