93 Accord got my ECU codes HELP ME
Discussion in 'Accord' started by 93AccordEX, Oct 14, 2007.
  1. 93AccordEX
    93AccordEX New Member
    93 Accord Help Needed
    Anyone with any ideas please help
    Car: 93 Accord EX
    ECU Code Returns:
    06 LED FLASH(s) 85-98 Accord
    ECT Sensor (Engine Coolant Temperature)
    defective circuit or unplugged / defective sensor
    08 LED FLASH(s) 85-98 Accord
    TDC Sensor (Top Dead Center)
    PROBLEM With car:
    When i go to start sometimes it would take about 4-5 seconds to start instead of the normal 1-2 seconds and the check engine light would come on
    BUT! while it was running if i reved it up and turned the key on and off quick it would go away and i would have no problems
    THE PROBLEM WITH THE LIGHT:
    The reason i need to figure it out is because when the light is on it has a safety to not let it rev past 3500rpm's
    THE CAR DOSENT LOOSE POWER its just like a rev limiter at 3500rpm's it doesnt just bog out at 3500
    If anyone knows a way to just unhook the safety rev limiter for now id love to know cause its killing me
    Update:
    Now that i thought about it the car did overheat for about 5 min's of running time before this started happening
    Update:
    iv taken the car too 3 shops and none have had an idea what could be wrong
  2. 93AccordEX
