93 B18a In A 92 4door
Discussion in 'HYBRID -> EG-EK / DC' started by gene, May 26, 2003.
  1. gene
    gene Junior Member
    hey I got a wicked deal on a 93 b18a motor..obd1. CAn I use the same mounts from the same motor/car or will I need 94-00 ones? also I need to know is the engine harness plug and play? any other things I should be concerned with? any help will be appreciatd thx.
  2. E_SolSi
    your gunna need the 94+ mounts i believe
    im also not sure if the linkage for the B18A will work
    you will also need to do somethiong about the cable tranny
  3. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Isnt the 90-93 tegs obd-0. The reference section is contradicting, saying its obd-1/0.
    Me confused :blink:
  4. E_SolSi
    pre 92 is obd-0
    92-95 is OBD-1
    the 2nd gen integra spanned 2 OBD generations
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    93 integra's are obd0
    i thought.. my b18a1 was obd0 i believe
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    No dude, 93 Integras are OBD1. Trust me. :)
  7. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    See, still confused. :blink: :blink: :blink:
  8. lsvtec
    It's OBD1, I drive one.
  9. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Ok, 90-93 tegs are all obd-0 then correct?
  10. SpoonSleeper
    SpoonSleeper Junior Member
    :withstupid:
    90-91 is OBD0---with clearish kinda white plugs
    92-93 is OBD1--- with gray plugs
  11. lsvtec
    No, the 90-91 are OBD0, the 92-93 are OBD1.
  12. gene
    gene Junior Member
    so with 94+ mounts it will fit then..
  13. bvm
    bvm Junior Member
    yes
