what kinda driveshafts would i used if i were to use a 93 b18a obd1 motor with a 95 jdm y21 tranny...would i use the b18a's flywheel?..btw this swap is going into a 92 ex 4 dr.....thanks for any input
i have done the exact swap so i will tell you that all you need is integra axles and yes the flywheel will work all you need is a clutch to fit the tranny not the flywheel
