93 Civic DX & B20 Swap
Discussion in 'Auto Multi-Media' started by Scorchin Civic, Sep 29, 2006.
  1. Scorchin Civic
    Scorchin Civic Senior Member
    Irving, TX
  2. Scorchin Civic
    Irving, TX
  3. Taco15
    Tallahassee Fl
    very nice. very clean. I love the color too. is that pearl blue or electron blue? whatever the civic si color is.
  4. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
    i think its a stock eg color, ive seen a few that shade runnin around. It doesnt look as bright as electron blue.
    What numbers you puttin down? mods? times?
  5. Scorchin Civic
    Irving, TX
    Thanks for the complement and this is a stock paint job. It's called Captiva Blue.
  6. Scorchin Civic
    Irving, TX
    I don't know what I am putting down yet but I will be getting it tuned once I find me a 4-1 header. As for times, I have only been to the 1/8 mile track and the best I have ran is a 8.80 and that was with 14 inch slicks.
    Here is the setup:
    Stock B20Z2 Block
    99 LS Head
    Port & Polished
    Three Angle Valve Job
    Crower Dual Springs & Retainers
    Crower 404 Cams
    AEM Fuel Rail, Pressure Regulator, & Cam Gears
    Walbro 255 Fuel Pump
    RC 310cc Injectors
    Skunk2 Intake Manifold & 68mm Bored Throttle Body
    Short Ram Intake
    DC Sports 4-2-1 Header
    Test Pipe
    Tusudo Catback
    B16 Tranny
    B & M Short Shifter
    Hondata S200 Running A Base Map Right Now
  7. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Man.. with that setup I bet it's hard to keep traction...
    I'm starting to love 2.0's...
  8. Scorchin Civic
    Irving, TX
    Yes, it is! Depending on what type of pavement it is I will not get good traction until I shift into third. However, I am working on that. I bought me a Type R tranny that has a busted case so I need to find a good case to swap everything over. Then see how that helps out.
  9. Andrew
    Tallahassee, FL
    yeah, LSD's make a world of difference.
    Great looking ride- and a seemingly awsome engine setup. It doesnt look like you skimped on anything!
    +1
  10. Scorchin Civic
    Irving, TX
    Thanks! This is my second Civic that I have had with a B20 swap. The first one was a 92 VX and I just basically through it together. Ran very good but I was always replacing motor mounts. So long story short, it was wreck and I then bought this stock 93 DX. I told myself that if I was going to do another swap with this one then I am going to do it right this time. However, don't think that I spent a lot of money with what I have done here. Be honest with you, I bought most of everything you see from Ebay. It took sometime to find some good deals but I believe it was well worth it.
  11. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Great looking car mang. Is your bottom end stock???? If so you may be slightly
    over-cammed (if that's even a real word). I was running the 403's with my stock LS and I was over-cammed, my car was even dying at stop lights but that could have been the tune. Looks real clean though love the color. Good Luck with it.
  12. k20 eg
    k20 eg New Member
    belton mo
    i like the color and the clean angine bay
  13. k20 eg
    k20 eg New Member
    belton mo
    so what are you going to do
  14. 95CivicDxD15B7
    95CivicDxD15B7 Senior Member
    that what i want my civic to be liek!!!! :)
  15. k20 eg
    k20 eg New Member
    belton mo
  16. Andrew
    Tallahassee, FL
    You should toss a nice ole b16 head on it....
    My good friend Taco15 has one for sale right now...here
    you know you want to...
  17. Scorchin Civic
    Irving, TX
    I have not been on this site in a while so I thought I would post this picture of my Civic with the Si wheels.
  18. Andrew
    Tallahassee, FL
    Cool beans!
    You got plans for lowering springs?
  19. 95CivicDxD15B7
  20. Scorchin Civic
    Irving, TX
    I have my spring, Eibach Sportlines. It's just that I am trying to fined me a decent set of shocks so I can do everything at one time.
