93 Civic Ex/b18b1 Ecu?
Discussion in 'ECU's, Electronics, and Tuning' started by sek, Jan 10, 2003.
  1. sek
    sek Junior Member
    I am doing an engine swap in a 93 civic ex. the motor that is going in is a b18b1 from an 95 integra ls, the civic is currently an auto and I am going manual. the problem is that the ECU that came with the motor will not plug into the harness for the civic (factory harness). I guess my question is, since there is no break in the harness before it goes through the firewall, what do I need to do, or where do I need to go to get the ECU to connect properly. Any help is greatly appreciated.!
    P.S. all the rest of the harness obviously direct plugs into the motor.
  2. SolReaver
    SolReaver Senior Member
    I thought the obd1 p75 plugs right into the stock civic harness? Check your ecu for what code is on the label.
  3. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah dude that should plug in
