1993 Honda Civic Ex TURBO
SHOOT ME AN OFFER!!!
CLEAN TITLE> and in the picture of the front of the car. it looks like it has been in a wreck but the headlight tabs and the corners are broken. thats why the 1 pc headlights are going to go with the car.
Car Description
Engine :
-124580 miles
-Stock sohc vtec engine d16z6
-Aem Fuel Rail
-valve cover breather
-Tune up just done with new ngk spark plugs, wires, rotor cap, button, fuel filter, and oil change.
Turbo Consist of :
-Garrett T3/TO4b turbo 57mm trim 3"inlet
-OBX Tubular Turbo Manifold
-Turbonetics 42mm Deltagate Wastegate
-Turbonetics Downpipe with built-in O2 bung and Wastegate dump-tube
-HKS Super-Sequential B.O.V
-DSM Front mount Intercooler modified with side end-tanks
-Tap for oil sending line from block to turbo
-Turbo Tapped SOHC Civic Oil Pan (extra d16z6 stock oil pan)
-Steel Braided oil sending line for turbo
-Oil line for oil return from turbo
-Intercooler piping kit for 92-95 civic/del sol w/ Silicone Sleeves and hose clamps
-Set of check valves, vaccuum tees, vaccum lines required for use
-Autometer Sport-Comp Silver Face Boost Gauge
-Autometer Sport-Comp Silver Face Air/Fuel Gauge
-Walbro 255lp fuel pump
-vortech 12:1 fmu
Exterior:
-Milano Red
-There are some knicks and dents around the car but nothing very major.
-1-pc headlights with halos.black housing NOT SHOWN IN PICTURE.
Interior:
-Razo shift knob
-boost/vac and airfuel gauges on dash.
-Interior is 2 tone. grey/black
Suspension/Wheels:
-stock 2000 gsr shocks with neuspeed race springs
-Stock 14in steelies
Pros:
-Car runs super good. engine runs very very strong and great with good gas mileage. car has beated MANY hatches with b series swaps with no problem.
-Turbo spools up very fast around 2500 rpms no shaft play and spins freely and has a very nice sounding blow off vavle. (hks)
-Suspension rides very well. not that bouncey or annoying.
-There is no muffler but the piping is cut behind the driving so it would not be so loud.
-power windows/locks/sunroof works very good. CAR WILL NOT COME WITH DRIVER SIDE WINDOW SWITCH!!!
-Car does not smoke one bit and does not leak coolant. there is a small oil leak somewhere.but is nothing major. i believe it the oil pan nut not tighten. never checked.
Cons:
-Exaust piping rattles around 4000rpms but is nothing major. can be easily fixed.
-Car has an automatic brake petal. dont konw why.
-Front bumper has a dent on the driver side and some other dents around the car. would recommend a good paint job.
-carpet is loose around the side foot piece. could be easily fixed
-cruise control does not work nor airbag. im sure it could be easily fixed also.
car will be sold as is and will not be responsible for anything after car has been purchased. buyer will have to arrange pick up or shipping.
Car Description
Engine :
-124580 miles
-Aem Fuel Rail
Turbo Consist of :
-vortech 12:1 fmu
Exterior:
-Milano Red
Interior:
-Razo shift knob
Suspension/Wheels:
Pros:
Cons:
