93 civic VX code 48
dorknut
Dorknut
I have a 93 civic VX.
I tried replacing my old O2 sensor but was unable to remove it. I did get it to budge a little but was unable to completely remove it from the car. when i turned the car on, the CEL came on. I did the ECU quick check and came up with code 48, which is supposed to be [FONT=Verdana, Arial, Helvetica, sans-serif]the Heated oxygen sensor. I later that day was able to remove the O2 sensor and install the new one only to have the code continue. I reset the ECU but the codes still tripping. Has anyone come across this?
[/FONT]
The aftermarket's sometimes will make the light come on because the computer does not work with the non-oem o2 sensor's well. It is the same with the cat conveter's too.
