to make this swap easier, i'd run an obd1 chipped p28 or obd1 gsr ecu. its ideal to get a vafc to tune the motor properly...so id' get a vafc also.
now, as far as the wiring, i'd use the vx harness, which will only create one problem...and thats changing the o2 sensor from 5-wire to 4 wire. i've never done this, and i'm not positive the 93 vx's utilize a 5 wire o2 sensor but they might, so check for that. now, i know with the 92vx's they do have 5-wires...so i'm assuming honda remained consistent with this.
if you go with a p28, you don't need to run a wire to the knock sensor, because the p28 doesn't look for the knock sensor.
if you run a gsr ecu or p30 or p61 you'll need to add a wire for the knock sensor, or get it chipped.
you'll also need an obd1 distributor, and any vtec b-series distributor will work.
i think thats it, i can't really think of anything else.
good luck, take some pictures of the swap and let us know how things turn out, a type r bottom end is going into my car soon.
