93 del sol headunit not working!! help!!!!
Discussion in 'Car Audio / Security / Electronic Accessories' started by mib008, Jan 1, 2009.
  1. mib008
    mib008 New Member
    Mass
    i recently bought alpine iDA-x200 head unit for my 93 del sol, tried hooking it up and i have yet to turn it on. I didnt buy the adapter for it so i cut the old harness off and crimped the wires to the new alpine harness. Ive double checked everything many times and i know everythings hooked up right.....i think: white/blue (battery back up +) from the car to yellow (battery lead) on the harness, yellow/red (ACC+) to red (ignition) on the harness. Ive checked the fuses (except on the unit, i dont knw where it is) and theyre all good, ive connected the old ground from the head unit to the new one and grounded that to the chassis, the ground makes blue sparks if i take it on and off so there is power going to the unit but i dont know why it wont turn on. the illumination wires are correct too (red/black to orange on the harness) and all of the the crimps are insulated. driving around with no radio is starting to become really really boring.
  2. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    :whatafucktard:
    not to be too mean but seriously. harnesses aren't even ten bucks and they make it 100x easier. i wouldn't even no where to start. if you have a multimeter here is waht you do. with the key OUT OF the car touch the wires to find a constant 12V. once that is found turn the key ON and look for the other 12V. that one goes to the ACC of the headunit. normally red. secondly, create your OWN ground. just to make sure it is grounded. and u very likely could have fried your headunit. if u didn't your lucky, and if u did i hope u learned your lesson.
  3. rickshaw racer
    rickshaw racer New Member
    middle of nowhere
    by the way blue wire with white stripe is your remote, not batt back up. it goes to power lead for power antenna or remote lead on an amp.
  4. delsol88
    JC,MO
    man just splice your original harness back together, break down, and buy a $7 harness plug from walmart...seriously before u try to do it yourself and end up burning down a perfectly good sol.
  5. serrilion
    serrilion In my own little world! VIP
    Vermont
    um... hanyes manual dude will tell ya the wiring code :p or just type in google wiring diagram for... and ya it will preduce, take ya little CD player manual or the backing of it and be like ah purple is left so on and so forth... thats if u want to save $7 bucks and feel like playing match the wires!
  6. Matts96HB
    Matts96HB . Moderator VIP
    Here's for your car..
    Car Radio Constant 12v+ Wire: Blue/White
    Car Radio Switched 12v+ Wire: Yellow/Red
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Red/Black
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Blue/Green
    Left Front Speaker Negative Wire (-): Gray/Black
    Right Front Speaker Positive Wire (+): Red/Green
    Right Front Speaker Negative Wire (-): Brown/Black
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Blue/Yellow
    Left Rear Speaker Negative Wire (-): Gray/White
    Right Rear Speaker Positive Wire (+): Red/Yellow
    Right Rear Speaker Negative Wire (-): Brown/White
    For your deck, go here.. Alpine Electronics of America, Inc.
    Open the PDF, go to page 47. Print out the diagram for your deck. Take both to your car, check connections, make sure all connections are good. Try.
    If you cant do it after that, theres no hope for you..
    Good luck.
