93 Del Sol Left Out Of B Tech Articles?
...I am usuming they are refering to the target car being the 94-up del sol vtec?
looking for info on b18c1 into 93 del sol SI. appoligies if I missed something in faq's or search, i looked hard.
del sols are coverd in the 5th gen civic. its the same car.
basically, if its an obd1 usdm gsr swap, it will bolt right in, wire right up. all you need to do is add wires for the knock sensor and the IAB control.... wiring for that can be found in the 5th gen civic obd1 wiring guide.
if you get a jdm motor, or an obd2 motor, you have some more work cut out for you.
i know its the same car i was just reading, and it mentioned 94 and up del sol but not the '93. I thought (but am probly wrong) there was a generation change w/ the sol in '94? have i been missinformed?
thanks for the reply by the way. I'm sure you get a lot of stupid questions on here by people who are new to the world of hybrids.
there was no Del Sol VTEC in 1993, that's why--still the same chassis.
