93 Del Sol Si, Swap
Discussion in 'HYBRID -> EG-EK / DC' started by CrewDelSol, Oct 1, 2002.
  1. B16A2
    100.0%
  2. B18C1
    0 vote(s)
    0.0%
  3. LS/V
    0 vote(s)
    0.0%
  1. CrewDelSol
    CrewDelSol Member
    Tallahassee, Fl
    Just curious on some opinions. For a note I have to keep the engine completely stock for the time being, due to insurance and parents. I've noticed a few people have done a b16a swap into a Del Sol was looking for some input on that. And has anyone ever done the GSR? right now thats the one im leaning torwards. Or the LS/VTEC, which a friend is nagging me to do since he has an old LS engine rotting in his garage. If you've done any of these swaps into a Del Sol or know someone that has please post some positives and negatives if you could. Thanks. Looking to keep it pretty much an everyday driver, just going for a little extra pep to show off.
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If you can get the LS bottom end for nothing (or close to) and the sleeves are in decent shape, then the LSVTEC would be worth it. If you have to pay a lot for it or it needs new sleeves then go with the B18C. The swaps cost about the same if you have to pay for the LS block.
  3. pissedoffsol
    insert poll choice b16a3
    is a better swap for the sol
  4. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I would say get the LS block if you are getting it next to nothing and boost it! Also if you are in cali than the LS/VTEC swap will not get reffed! They will turn you away!
  5. lsvtec
    Or you could pull your eyballs out, that would be about as much fun.
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Well the del Sol is a heavy car because of more supports for the targa top. It is much better to put the gsr instead of the b16 in there because of the extra tourque. Spend the xtra little cash and go for the gsr. If you do put an IS/VTEC in there it is alot of work. (READ THE FAQS about that one.) With the weight of the sol you sould get gsr or is/vtec. my vote is for the gsr. If you had a hb, i would have voted for the b16
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i'd do an ls/vtec if i did it over again
  8. lsvtec
    I love mine, but the only reason I went LSVTEC was I already had the LS block so it was actually cheaper than doing a B18C1 swap. There is no real benefit to the LSVTEC if you don't have access to a cheap/free LS bottom end. (I don't count 35 cc's a big benefit)
  9. TrueStifmeister
    TrueStifmeister Junior Member
    B-more
    Was it the CRX or the del sol that when you did a b18c1 swap you had to raise the car because the oil pan.....? I think it was CRX so the b18c1 sounds like a plan, why not ball out wit it?
  10. cxjon
    cxjon Senior Member
    man+k+toe
    b16a3 would be a good swap
  11. SolReaver
    SolReaver Senior Member
    gsr for na
    ls for turbo
  12. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    depending on the condition of the ls i say lsvtec... but if you're gonna go lsvtec, dont try to be cheap about it, build it right while you're in it.
  13. paragus
    paragus Senior Member
