93 Del Sol z6 Greddy 15g Exhaust question
Discussion in 'Forced Induction' started by xJJx, Apr 1, 2011.
  1. xJJx
    xJJx New Member
    Hello all, I just have a few questions that you might find stupid [​IMG]
    I recently bought a 93 del sol with the d16z6 on it with the intent to install the Greddy td04h-15g bolt on turbo kit. When I bought the car it had dual exhaust (Why? I dunno). My first question is since I'm not really going balls out just want a little more power is it worth the money to switch it back to a full 3" system and what would be the benefits? Also, With this being my first install, where would be the best place to tap into on this motor for my oil pressure and for my Air/Fuel (Or is there a bung already there with the kit for it)?
    Also, I've found the kit at a few different places:
    mvpmotorsports.com - 1952.25
    titanmotorsports.com - 1525.00
    optionimports.com - 1952.25
    autocarparts.com - 1874.16
    importparts.com - 1995.00
    Anyone ever bought anything from titanmotorsports? Kinda iffy about there price being that much lower then all others and kit hasnt been order yet so if anyone can recommend a trusted site that would be awesome.
    Thanks in advance!
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you can run a sandwich plate on the oilfilter for oil feed or you can run a t-fitting where the oil pressure sensor is on the back of the block..
    also the downpipe should come with a bung for an o2..
  3. Matts96HB
    Matts96HB . Moderator VIP
    also, a 2.5" exhaust will suffice for your situation
