so just nevermind about the head swap, my prelude, when its coming hot, deosnt idle well, like up down up down, and when I want to drive it i need to tap de gas pedal or it will cut or just die...can someone help me
Try cleaning the IACV and FITV. Also, check your coolant; make sure it has been bled and check your PCV valve(good to replace in general). After that, unhook the battery for about 10 seconds and reconnect it. Then, let the car idle for a bit.
