93 hatch cx 1750 f/s and f/t
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by tofasttoslowforyou, Sep 25, 2009.
  1. tofasttoslowforyou
    tofasttoslowforyou New Member
    Location martinsburg wv 25405
    ONLY TRADES I AM looking forward to are 92-95 or 95-96 civic 4 door ONLY. WILL CONSIDER 4 DOOR TEGS 94 AND UP ONLY!
    car has 133xxx miles on it
    car is not legal so no test drives or delivery of car
    THE AC MUST WORK OR THE CAR HAS TO HAVE POWER WINDOWS. Auto or 5spd dont matter.
    Needs to have minumum work needed to it.
    Body condition would prefer to have little or no rust as mine dont. Also consider ones with rust or miss matching body panels
    I wont add cash so you need to be equal or lesser value.
    Price is firm!!!
    Up for sale or trade only for a 4 door civic or teg. The car does not need anything major or minor i just need a 4 door bad. The only issues with car is the driver door locks from out side only as the inside lock handle is broke and car idles low when its cold out.
    Pros:
    stock.
    gsr grey leather
    working cd player
    stock tach
    runs and drives great.
    gets 40-50 mpg.
    new driver axle with life time warranty
    new lower ball joints both side life time warranty
    tires have 70% life left
    new inspection for wv 8-10 exp.
    new front window
    front and back gray gsr leather seats worn but no holes and foam is not deterorated
    minus the very small surface rust spot the size of a pencil tip eraser. there is no rust elsewhere.
    Cons:
    No ac... Did not work, tryed to fix it numerous times and all have failed so it was removed.
    front bumper was stolen so i replaced it with what ever i could find.
    hood is flat black
    fart can with gutted cat
    low idle
    no ant. as its been broken off so cant listen to fm radio
    has dx trans
    has some wear on seats
    has an auto cluster
    has a surface rust spot size of a pencil tip eraser on pass side rear
    has some clear coat fade on roof
  2. tofasttoslowforyou
    ttt
  3. 95b16coupe
    95b16coupe New Member
    ct
  4. tofasttoslowforyou
  5. tofasttoslowforyou
  6. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    Just curious here, does the car just have expired tags or what?
  7. tofasttoslowforyou
    expired registration and no ins on it
  8. CIvic COUPe BOOOOSSSSTTTT
    CIvic COUPe BOOOOSSSSTTTT New Member
    sup
    got a ek coupe for you auto nice condition wit new y8 swap
  9. tofasttoslowforyou
