93 hatch..what should i swap?
Discussion in 'HYBRID -> EG-EK / DC' started by VuDuDuOnU, Dec 29, 2002.
  1. VuDuDuOnU
    VuDuDuOnU Member
    were can u find these facts? asmallsol
  2. kyleirwin
    kyleirwin Retired OG
    Vegas
    it's common knowledge bro.
    1.8l < 2.0l
  3. SolReaver
    SolReaver Senior Member
    FAQ=Frequently asked questions, not facts
    Small sol, how exactly did you come up with 6K for a crvtec build? I sure as hell hope you get EVERYTHING replaced with top notch parts for 6k.
    I would say a basic build for a cr vtec would be around 2500-3000. The blocks are hella cheap, prolly no more than 300. heads are around 600, tranny no more than 600 and a bunch of miscellaneous parts would be at most 1K. How exactly does 2500=6000??
  4. chet
    chet Senior Member
    st petersburg, florida
    because you didn't figure in machine work.
    plus a crv block costs 800.
    resleeving costs 800.
    transmission costs 800-1500
    head costs at least 600
    crvtec's are expensive and not reliable if they aren't built properly...and few people know how to build them properly...
    get a b16a, b18c, and go from there, with some work both motors can make a hatch a mid 13 second car.
  5. SolReaver
    crv blocks have to be sleeved to make them work with the vtec head? Im talking about a basic build here, enough to get you running. Better stuff is optional, just like on any other motor.
    And I have never seen a crv shortblock for more than 500 bucks
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    you have to replace just about everything in the engine because the bottom end can not stand up to high revs with stock intrenals. It is the same way with lsVTEC's. If i had the cash, i would do a crVTEC over any other honda engine.
  7. BOBO
    BOBO Junior Member
    B18a releeve (golden eagle) 86mm bore
    custom 12:1 (stock rods)
  8. chet
    chet Senior Member
    crv blocks usually crack sleeves between 2nd and 3rd cylinders when driven hard...etc.
    i've seen this happen first hand...therefore i'd resleeve it if you're going with anything over 10.5:1 compression.
  9. 2 litre EG
    2 litre EG Senior Member
    so cali
    :withstupid: :D
  10. asmallsol
    where did the top post go?
