93 hatch with b18b swap
Ritzbitz
Ok guy I have a 93 eg hatch with a 95 b18b manual rumning off a p73 with ls stock maps. Im having an idle problem when I run the car hard ( switching gear at 5k). When I come to a stop my idle drops down to about 400 and car bogs but doesn't stall. I can drive it but it hesitates and feel like it misfires, I have to turn the car off and start it back up and everything goes back to normal (idle goes to 900 and no hesitation). If I drive the and swift a 4k it won't do it. Any suggestion on where to start?
maybe the fast idle thermo valve (FITV) on the bottom of the throttle body, needs to be cleaned and the plunger tightened. Thats where i'd start.
the vibration at high rpm's could cause fitv plunger screw to lossen , so you need to clean and tighten screw like prmeredseol said ,good tip bro,lol....
