93 integra gsr aztec green. swap ls/vtec
stevo009
hey i have a 93 gsr integra with 144,000 on body 95,000 on motor. manual. armrest. if anyonie is interested ill put up pics and all details. im in fairfield in between sacramento and san francisco.
3500 O.B.O The front fender got bent. Cost like 300$ or less. Still looks fine. Needs new vtec sylanoid gasket.
Has Jdm armrest. Black leather interior. Tears in front seats only. Shortshifter. Intake. Tires less than 6,000 on back 2,000 on front. Gsr blades rims. Pioneer deck. If the gasket gets fixed the vtec should kick real hard. Has dents in front right fender but they could be removed.
The vtec solenoid should work even if the gasket is damaged. Sure, you will leak oil, but that shouldnt affect vtec engaging. Low oil pressure will cause vtec to not engage. Notice when vtec engines are cold, and you try to rev up to vtec crossover... nothing. The engine cannot build enough oil pressure when the oil is cold.
