k thanks. few other small questions. doing a swap into a 92 hatchback. i have axles from a gsr on a crx that im gonna use, got a 95 ls wiring harness and ecu for the swap. i have the 95 ls mounts, will they bolt on the 93 to the hatch?
k lemme rephrase all that mess. will axles from a gsr thats on a crx work on the hatch with the ls? i dont see why not. will mounts off a 95 ls bolt on the 93 ls and onto the hatch
k well then im pretty sure im set. motor is ready to drop in. i have a 95 ls tranny manual for it as well. anything else i should know or keep in mind or preform?before i begin this swap?
hmm well in that case would you know which axles i can use for the hatch? i didnt get any axles with the motor. all i have is the hatchbacks acles and the crx's axles with the gsr in it
