93 prelude swapped h23a3 wont idle help me
Discussion in 'Prelude' started by stephenmunoz, Apr 27, 2009.
  1. stephenmunoz
    stephenmunoz New Member
    was standard converted to automatic . motor starts but wont idle change distributor rotor cap wires , plugs fuel injector . i have both ecus for auto a standard dnt make a difference help me plz
  2. stephenmunoz
    it had h23a1 i put the h23a3 it runs but eats up gas and wont stay runnin wen i give it gas itl hesitate somtimes then go it was worse the throttle got more responsive but it still not running rite pl z help me
    1 person likes this.
  3. Ethan
    Ethan Well-Known Member
    Maybe you should buy a chevy?
  4. DESPAIN
    flower mound TX
    I think you need to change the dizzy. OR YOU MIGHT HAVE A BAD ECU?
  5. Ethan
    I was there and i know he changed both with no luck. :(
  6. sjaak
    sjaak New Member
    netherlands
