stephenmunoz
well i took out the h23a1 an swapped it with h23a3 . the car was 5spd now is automatic. everything is done beside it running. well it starts but wont stay running .
i changed. plugs.rotor.cap.distributor.fuel injectors. ecu. an has got better throttle is more responsive.but takes a while to start.. help me plz. it revs up good but bogs at. first. i took a test drive itl run good then bog run good then bog .an eats gas like a mofo i changed some things today an it got better but stil wont ile help me
