I have considering swapping out my current stock suspension for a USDM ITR 5 lug conversion, having searched the past nine weeks with no luck I decided to try another possibility EK9 5 lug conversion (32mm). Any one know what the difference between the two swaps if there is any. Will my ITR 15's fit. To all those who contribute, thank you.
if you are planning to swap the entire suspension over then the ITR will be easiest as it will come with the ITR LCSa which will be needed other than that they will be the same
