93 starting problems
Discussion in 'Accord' started by ruhbrducky, Dec 2, 2010.
  1. ruhbrducky
    ruhbrducky New Member
    93 Honda Accord, 5 speed man. 280k miles
    Ok well there seems to be no apparent patern to this problem but here goes...It will crank but not start. Leave it alone for a couple hrs to a day and it starts like nothing was ever wrong. Does it hot or cold. What we've replaced....main relay, temp sensor, Ignitor and distributor cap. We've checked....fuel pump, spark plugs.
    Wondering if its the Ignition Switch?? Any ideas or suggestions??
  2. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    everytime it does not start is it moist, because if moisture gets in the distributor there is your problem, could be ignition switch, or a bad engine/chassis ground
    also welcome to hondaswap
  3. calmfornow
    Zionsville, pa
    and since you said u checked spark plugs, you probly checked if your getting spark to the plugs, also try to check TDC and see if the timing is correct
  4. kody.price92
    kody.price92 New Member
    Tn
    Mine doin the same man an I've replaced almost everything that deals with the firing system but for whatever reason still can't get power past my external coilpack
  5. kody.price92
    Tn
    An did u manage to figure out
    Oh an shot in the dark but check the capacitors on your ecm
  6. hondarin
    Texas; where else?
    Is there moisture in the floor around the ecu?
