93 Vx Hb Doing Jdm Itr Swap
civictyper23
need help for wiring i have 5 wire o2 and what else would i need to wire
thanks for all your help
any site links or any help will be good
Youve gotta change over to obd2 dog. Use the itr harness, ecu, ect. unless you wanna source an ecu, distributer and such from a 94-95 gsr. That might be the easiest route unless youre already packin the itr stuff.
i have an ITR in my 93 sol
you dont need to convert to OBD-2
use a chipped P28 or a P30
use your harness
swap the plugs for the:
injectors
distributor
alternator
its easy
use your harness
injectors
distributor
alternator
its easy
listen to E_Sol, that's the easier route.
