94 Acc. Engine Swap Non-vtec To Vtec
Discussion in 'HYBRID -> BA-BB /CA-CD' started by BMEagle7, Feb 16, 2003.
  1. BMEagle7
    BMEagle7 Junior Member
    I was wondering what will be needed besides the engine itself. I have a auto tran.
    I need to know if the ecu and/or the tranny computer will have to be changed and or other
    modifications will be needed...
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Yes, the ECU will have to be swapped, along with a complete head (distributor, cam, cam gear, timing belt...) and (I think) a VTEC water pump.
    Are you sure you want to do this swap? It's only going to net you aout 10 horsepower at the flywheel.....You may be better off saving for a turbo or an engine swap.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I don't think that he is swapping the head, I think he is swapping the entire engine.
  4. dohcvtec_accord
    The left lane
    Ahhh, that makes sense. It still brings about the question of, do you really want to swap a whole engine for an extra 10 horsepower?
  5. ratherbewalking
    ratherbewalking Junior Member
    Whats the difference between the v-tec and non-v-tec water pumps?
  6. dohcvtec_accord
    The left lane
    I can't say for sure on the F-series, but I know that on the B-series, the water pumps differ in the number of teeth of the pump from non-vtec to vtec. Best way is to go to the Honda dealer and ask them to show you a pump from each engine, then compare them.
