94 Accord EX H22 OBD2 to OBD1 help.
Discussion in 'Accord' started by lurch, Dec 7, 2011.
  1. lurch
    lurch New Member
    I just picked up an obd2 h22a4 and i am swaping it in to my 94. i know i need the dizzy and injectors and an ecu, My question is will the p13 ecu swap directly in the car with no messing around. Will a chipped p28 bolt in with no other modds to the wiring go in. So can i use a p13 without changing wiring and/or a p28 without changing wiring.
  2. FLACOFOOL80
    FLACOFOOL80 Banned
    the most least expensive ecu that can be flashed for an h22 basemap is a p06 chipped, thats wat i got in my 95 accord w 95 h22a basemap. tell ur ecu guy to program vtec to kick in at 3700 rpms and also to program a rev limiter. off the line it wont let u go over 2500 rpms, to prevent spinning tires. as for any other wiring u might have to run one wire to the IaB. pin a06 out of the ecu. oh and u have an usdm h22a4. which is 190 hp with 290cc injectors. jdm h22a r 220 hp w 315cc injectors and dont have knock sensors.
    Ur gonna have to run a wire to the knock sensor which is also one wire out the back of ecu. i think its pin A11
  3. h22160dbaccord
    h22160dbaccord Hollywoods World
    p28 plug in and eliminate knock sensor
  4. h22160dbaccord
  5. FLACOFOOL80
    FLACOFOOL80 Banned
    heres my swap guide. dont forget to wire up ur fuel injector resistor box by the left
    hood hinge or else it wont start
    print it
