My lug nuts were loose for days. I got so many mechanics opinion on what the noise was. None of them guessed it wouldhave been my lugnuts or else I wouldnt be here today asking for help. So could anyone please tell me how to remove the wheel studs. Two of mine are bent and also should I replace the one or two that are bent or replace all four?
you will need to remove the hub with a slide hammer or you can use a press whith will requiure you to remove the whole steering knuckle. when the hub is out, try to secure it in a vice. then it only takes one good shot with a hammer to get each stud out. good luck!
