B16ASilverhonda
Member
I have a 94 B18b Longblock For Sale that has basically all new seals:
Includes New:
Oil Pan Gasket
Rear Main Seal
Crank Seal
Headgasket
Camseals
Valve Seals
Head Resurfaced
Water Pump
Coolant Pipe Seals
Thermostat
PCV Valve
Timing Belt
Distrubutor Seal
Distrubutor Cap
Distrubutor Rotor
Intake Manifold Gasket
Exhaust Manifold Gasket
Valve Cover Gasket
Valve Cover Mounting Bolt Gaskets
Basically this motor has been rebuilt recept for the piston rings. Invested $450 alone for all the gaskets from OEM Acura/Honda
Motor has 60-70k on it. All of this can be yours for $800 FIRM
Also have some GSR Hammers. Tires need to be replaced at about 20k more miles. $300 FIRM
Have some VX Wheels Painted Black 80% Tire tread. $200
Cell: 540-379-9290
AIM: NstyGrnHatch
Includes New:
Oil Pan Gasket
Rear Main Seal
Crank Seal
Headgasket
Camseals
Valve Seals
Head Resurfaced
Water Pump
Coolant Pipe Seals
Thermostat
PCV Valve
Timing Belt
Distrubutor Seal
Distrubutor Cap
Distrubutor Rotor
Valve Cover Gasket
Cell: 540-379-9290
AIM: NstyGrnHatch
