94 civic dx/w obd1 h22 external coil wiring
Discussion in 'HYBRID -> EG-EK / DC' started by xplicitcivic94, Nov 11, 2010.
  1. xplicitcivic94
    xplicitcivic94 New Member
    My question is, with the external coil, where do i splice into and match what wires? On the dizzy, there are two plugs, one 8 pin and the other is 2 pin. coming from the harness, theire is a 7 pin plug and the 2 pin plug. which plug do i use to splice into for the coil? its a 4 pin but there are only 3 wire. would really appreciate the help. If anyone has a diagram or step by step write-up, i would greatly appreciate it
  2. hondafreak513
    hondafreak513 New Member
    O hi O
    You should just have to run the +and- from inside the dist. to the external coil. I don't remember the colors of the wires to use outside the dist.
  3. xplicitcivic94
    thanks mane!
    does anybody know which wires are positive or negative?
